Duplicate entry '2147483647' for key 1
Thread begun 9/08/2009 2:24 am by Suggs | Last modified 9/10/2009 9:39 am by Jason Byrnes | 7489 views | 5 replies |
Suggs
Hi Folks,
I have started getting this error when using DA to try and insert a page into the database.
i have checked the database and all seems fine (the ID field is a primary key, int not null, auto increment)
The database works sweet when you upload a record via navicat however when you manually try to insert a record, it creates a long ID as above and then when you try and insert another record it comes up with the Duplicate entry '2147483647' for key 1 error.
Any help will be greatly appreciated.
Cheers
Paul
The limit for a Signed Integer column is -2147483648 to +2147483647, for an Unsigned integer column, the limit is 4294967295.
Change the ID column to an unsigned integer.
See the following for more information:
numeric-types.html
Suggs
Hi Jason,
Thanks for this,
The thing is, when i add a new product, it assigns the ID 2147483648 instead of the next ID in line which should only be 158839.
it has done this even with changing the value to unsigned
i have been using DA for some time and on quite a few builds and this is the first time this has happened.
Cheers
Paul
Are you assigning a value to the ID Column in the Insert Record Server behavior? This could cause the sort of behavior you are experiencing.
Suggs
Hi Jason,
Im not assigning a value to the ID column.
Ive attached the Insert Record Wizard listing in gif format for you to see.
Ive also attached a copy of the insert file for you as well.
The record insert file contains digital file pro image upload fields as well, however ive regenerated a new insert form using the Data Assist Wizard to test it with and its just writing the same ID numbers as before.
When you try to insert a product it appears in the database as ID 214xxxxx instead of the next number in sequence and instead of going to the detail page, it returns to the insert page along with this error message at the top of the screen:
Warning: Cannot modify header information - headers already sent by (output started at /home/barkerde/public_html/admin/productimport_Insert.php:142) in /home/barkerde/public_html/admin/productimport_Insert.php on line 169
Cheers
Paul
Im not sure how to check this using PHPMyAdmin, but it should be similar:
In The MySQL GUI Tools open the MySQL Administrator. Select your Schema, then double click the productimport to bring up the table editor. On the Advanced Options Tab, The Auto Increment option lets you set the next key to be used.
For the error:
Change line 140 - 142:
