blocking a tld
Thread begun 10/05/2017 1:05 pm by p_vouers282571 | Last modified 10/10/2017 4:14 pm by Ray Borduin | 5329 views | 14 replies |
p_vouers282571
blocking a tld
is there a way with the form validation to not allow any email addresses ending in .ru
Are you using client or server validation? I'm sure it can be done with a regular expression.
p_vouers282571
client side. I want the form to fail if the email address ends with .ru
I looked into this and it wasn't really easy to do. So I updated the jquery.h5validate.js file to make it possible.
Replace your version of the file with the one I have attached.
Then you can add a new attribute to your input field that you want to add the validation to like this:
html:
<input type="email" validate="notspam"
And then add a function to defile what notspam means like:
<script>
function notspam(el,val) {
var notAllowed = /\.ru\s*$/i;
if (notAllowed.test(val)) return false;
return true;
</script>
p_vouers282571
thanks BUT this is weird. When I submit the form it WILL NOT send the email to the BCC (me) BUT it still goes straight through to the main site email.
I never used jquery validation so I am probably doing something wrong. Here is the link to my contact page.
https://jwdrivingssl.com/contact.php
Your jquery validate scripts have to be below your jquery includes... and you have to use a separate <script> tag for your inline script, you can't combine it with an external script file. So this code:
<script type="text/javascript" src="webassist/jq_validation/jquery.h5validate.js">
return true;
</script>
needs to look like:
<script type="text/javascript" src="webassist/jq_validation/jquery.h5validate.js"></script>
<script>
return true;
</script>
And all of that code needs to move down to below the jquery.js code reference.
p_vouers282571
still no go, must be me. See attached private msg
I can't debug it easily looking at the script. Do you have a URL? I see the old url you gave hasn't been updated.
p_vouers282571
is the current version. I just uploaded it
p_vouers282571
also the script DOES BLOCK the email to the bcc, but passes it to the main email
