Multiple delete issue
Thread begun 10/02/2017 10:52 am by danielsebas | Last modified 10/02/2017 2:01 pm by Ray Borduin | 1863 views | 3 replies |
danielsebas
Hi Ray, I applied in a page 2 multiple delete behaviors and a single delete behavior. I need to make a multiple delete from an orderdetail table and from an inventory table and a single delete to delete the record from de orders table but only one multiple delete is working (the orderdetail). How can I make all of them work?
You don't need to use the multiple delete server behavior for this. Since you are only deleting based on one value... the OrderID and you are deleting all records that match that OrderID. You can use 3 single delete server behaviors.
danielsebas
Thank you Ray, it worked perfect! So multiple delete is for info that is not attached to a same ID?
That is correct. Like if you had multiple orders you wanted to delete based on which ones you checked in a result list.
