Checkout Page Not Working Correctly
Thread begun 9/26/2017 1:04 pm by sjones435326 | Last modified 9/26/2017 6:43 pm by Ray Borduin | 830 views | 1 replies |
sjones435326
Hello, I'm having an issue with the checkout.php page.
1) I have ran the Checkout wizard and the checkout page did not work, so I deleted all of the page created and ran the Wizard a second time - checkout page did not work again.
2) Unistalled eCart and shut down DW CC2015
3) Re-installed eCart and ran the Wizard again and checkout page is still not working
I'm going to attach the checkout.php file as well as a .txt file of the source code that the page is putting out. Can you tell me if the Wizard is generating the correct file?
It is adding the page content above the <body> tag. I think if you move the code on lines 27-974 down below the <body> tag that will fix it.
I'll have to investigate why eCart would do that.
