Moved to New Server and Dynamics Droplists stopped working
Thread begun 9/18/2017 10:26 am by vernon webb | Last modified 9/18/2017 3:12 pm by Ray Borduin | 4962 views | 13 replies |
vernon webb
I have moved all the files and pages to a new server but the Dynamic Dropdown Lists have stopped working. It has been a really long time since I've done this. Is this some time simple I may have done wrong that some one could point out to me?
Here's the the page:
http://dev.rsavvy.com/time/user_times_Insert.php
The issue is that the company list isn't getting populated to begin with. You can't have a dependent list if the parent list is empty. I'd have to look at the code to see why. It could be that the company table in the database isn't populated correctly.
vernon webb
I'm not really sure what that means. If I test any of the list they do come back with results. And this all works on the live server.
If you give me FTP access then I could take a look. What is the first list that has child lists? It should be populated from a recordset. Does the recordset return results?
vernon webb
Company is being populated by a dropdown list based on the first dropdownlist (active/inactive)
There is no onchange event for the clientStatus list that would populate the company based on its value.
vernon webb
It's set to onload in the <body> tag
There is no mention of the clientStatus list in the body onload event.
vernon webb
Please look at this one and please don't submit the form as it is a live page:
http://www.rsavvy.com/time/user_times_Insert.php
On the top of the new page you have:
var activeCompanies = ;
var inactiveCompanies = ;
the old one has values on those two lines. It appears to be custom code you have added. That is the part that isn't working on the new site.
