Getting error message with a project we did in premier support
Thread begun 9/15/2017 7:35 am by russb335115 | Last modified 9/18/2017 9:05 am by Ray Borduin | 1970 views | 4 replies |
russb335115
I'm having an issue with a form filter that the submit button is showing "This field is required" when it is press. See attachment
You haven't attached an image. Please post a url to the page. I wouldn't be able to debug an attachment anyway. You may just have to remove the "required" attribute in the html.
russb335115
Hi Ray,
I thought the image was attached, I'll try again. See PM four URL
I see that it is still working on this page:
http://antronix.com/antronix-Products-All-ResAmps-results.php
It looks like you may have added a different version of the jquery library on the other pages which may be incompatible. You also seem to have multiple jquery includes on the same page. I'd try removing the repeated jquery references and just have the one from the working page and I imagine that will fix the problem.
russb335115
That did the trick, thanks Ray.
