MySQLi Login has broken since updating site with a SSL certificate and static IP
Thread begun 9/06/2017 3:36 pm by davidtricker376400 | Last modified 9/07/2017 8:28 am by Ray Borduin | 3181 views | 4 replies |
davidtricker376400
Hello,
I've been running this site and cms (in a subdomain) for a couple of years. Yesterday the client wanted to update to a https address. I purchased a PositiveSSL Wildcard and Static IP from JustHost and after a couple of hours the front end was working; the cms subdomain was not.as it was were the site images were stored. Reading further I updated the .htaccess file with the following code:
# Justhost.com
#.htaccess WildCard SSL
RewriteEngine On
RewriteCond %{HTTP_HOST} ^subdomain.example.com$
RewriteCond %{REQUEST_URI} !^/subfolder/
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)$ /subfolder/$1
RewriteRule ^(/)?$ subfolder/index.php [L]
Substituting my subdomain and domain. Hooray. Everything worked.
I tried to login to the CMS only to discover that the page would refresh with the subdomain/index.php url and an error Error in SQL syntax.
I have done everything I can think of to fix this problem. Any help would be greatly appreciated
Can I get a url to reproduce the problem and the username and password you used in the private area. I may need FTP access as well in order to fully debug and find the solution.
davidtricker376400
Thanks Ray, requested information sent via PM
You didn't update your connection for the domain: cms.yoursite.com
So it was trying to use your testing server connection information and failed to connect to the database. I updated the connection file and it appears to have fixed the problem.
davidtricker376400
Ray, thanks for looking at this, From the form submission of the cms index.php page, a successful login should take you to cms.domain.com/pages/ folder, your amendment makes it clear that the page is instead taking you to cms.domain.com/index.php, which is a .htaccess mirror of the domain.com/index.php page. I think something is missing from the .htaccess allowing other pages in the subdomain other that index.php, /pages/index.php for example.
I've now updates the .htaccess record, which stops the redirect, the form on the CMS login page now redirects successfully.
Many thanks again for looking at this.
