Settings to test sendmail function using MAMP PRO
Thread begun 8/31/2017 8:30 am by s.joiner74419001 | Last modified 9/02/2020 8:40 am by Ray Borduin | 3797 views | 6 replies |
s.joiner74419001
I have wanted to test various web pages that uses the sendmail function and I am wanting to test them locally using MAMP PRO. I believe for the postfix settings within the MAMP PRO interface all I have to enter if I'm testing to my own email is the domain for the particular email I am sending to ( see attachment 01)
I am unsure what settings I use for the 'Universal Email Behaviour" within Dreamweaver ( see attachment 2 )
Thanks in advance!
To have your localhost send email you need to install a local SMTP server configured for email relay.
If you want to use a remote smtp server you would likely have to use the PEAR mail option for authentication.
s.joiner74419001
an old problem re-visited!
OK so years later I still haven't got this sorted.
here's the current circumstance.
For some reason when I am in the office and I'm testing our application system that on certain functions fires emails to the customer and back to us.
When I use emails that are provided by our host as dummy customers, the emails seem to send, even though I am testing on a MAMP setup. But more predictably won’t work if I test using gmail, iCloud etc.
So i’ve been able to test with no problem and haven’t needed to pursue with your suggestion of installing a local SMTP server and use the PEAR mail option for authentication.
However since working from home due to COVID, all be it on the same computer that I bring home, trying to test mail using the same email addresses from our host does not work. Which just baffles me. I don’t understand why change of location would be different, or why it would even work from the office using remote host emails, even though I am using a localhost. Maybe there’s a logical reason for this beyond my knowledge.
I have read about setting up Postfix in MAMP pro, where you use what is called “a smart host for routing” but I am completely out my comfort zone with this and just can’t get it to work when testing the send mail scripts from WebAssist. Not sure this is even what I should be doing.
Any further advice to this would be great!
Thanks in advance!
Steve
If you use DataBridge v2 we have a newer, better, email solution. It will allow you to use authenticated emails without PEAR and will improve email deliver-ability and any location variances. I'd start by migrating to DataBridge v2 and use SMTP authentication when sending emails.
s.joiner74419001
I'm currently on Databridge Version 2.3.5. Is that the latest version?
Yes... If you re-apply the email server behavior it will update the code base. Go to the email server settings and set it to use smpt and enter your email server credentials.
s.joiner74419001
Thanks Ray.. Got this working after a few tweaks.
