WA Dependent Dropdowns
Thread begun 8/28/2017 3:24 pm by danielsebas | Last modified 8/29/2017 9:16 pm by Ray Borduin | 1669 views | 2 replies |
danielsebas
Hi I put a dependent dropdown with WA Dynamic Array in an insert page. The dependent Dropdown works great but I will like to put as default value a State and a City when I load the page. How can I do that?
Thank you.
Regards,
Daniel
The first dropdown you can set the default with the standard dreamweaver properties window.
In order to set the child defaults you would have to take the onchange code from the list and call it onload of the page, then there is another webassist behavior to set the value of the list onload as well.
danielsebas
Thank you Ray. It worked perfect
