code updating 2
Thread begun 8/16/2017 8:26 am by Christopher West | Last modified 8/16/2017 1:19 pm by Ray Borduin | 1111 views | 2 replies |
code updating 2
Hi Ray, I have the following old code (using old mysql server behaviours) and which to change it to mysqli
$colname_ItemOptions = "-1";
if (isset($_GET['Product'])) {
  $colname_ItemOptions = $_GET['Product'];
mysql_select_db($database_dinkydb, $dinkydb);
$query_ItemOptions = sprintf("SELECT optiongroups.*, OptionRequired, OptionIncluded, ProductOptionID FROM productoptions INNER JOIN optiongroups ON optiongroups.OptionGroupID = productoptions.OptionGroupID INNER JOIN products ON productoptions.ProductID = products.ProductID WHERE ProductLink = %s ORDER BY OptionSort, ProductOptionID", GetSQLValueString($colname_ItemOptions, "text"));
$ItemOptions = mysql_query($query_ItemOptions, $dinkydb) or die(mysql_error());
$row_ItemOptions = mysql_fetch_assoc($ItemOptions);
$totalRows_ItemOptions = mysql_num_rows($ItemOptions);
is below correct change from above:
$rsItemOptions
= new WA_MySQLi_RS("rsItemOptions",$ecartdb,0);
$rsItemOptions->setQuery("SELECT optiongroups.*, OptionRequired, OptionIncluded, ProductOptionID FROM productoptions INNER JOIN optiongroups ON optiongroups.OptionGroupID = productoptions.OptionGroupID INNER JOIN products ON productoptions.ProductID = products.ProductID WHERE REPLACE(ProductName, ' ', '-' ) = ? ORDER BY OptionSort, ProductOptionID");
$rsItemOptions->bindParam("s", "".(isset($_GET['Product'])?$_GET['Product']:"")  ."", "-1"); //colname
$rsItemOptions->execute();
Close, but why have you changed the WHERE clause from:
other than that they appear to be direct translations of each other and correct.
Hi Ray, good question regarding WHERE REPLACE(ProductName, ' ', '-' ) = ?
Basically I am using a more recent ecommerce website I put together and in that code I used the above where statement so that the URL would always replace any spaces with hythenss in my product names (there was a logical reason for that approach but its been some time since I did it).
Chris
