SiteAssist Pro 1.06 - Unable to Save Site Config
Thread begun 9/07/2009 4:37 pm by michael.green134675 | Last modified 9/08/2009 1:36 pm by Jimmy Wu | 2035 views | 1 replies |
michael.green134675
Hi, I have created a site configuration/layout that I want to keep for future projects, but I keep getting the following error:
The Following Errors were found: Site Type Name Must Be unique
I have tried numerous different names but it comes up with the same error each time.
The base program is DW CS3 with the latest version of SiteAssist 1.06 installed as the extension.
I have encountered proglems with previous versions of SiteAssist, but this is a new one on me.
I look forward to receiving your reply and hopefully a fix to this problem.
Many thanks in anticipation....
Jimmy Wu
I wasn't able to reproduce this issue on my end. Are you able to complete the wizard using the other options (dont save and overwrite)?
One thing you can try is to hit tab after entering in the name you want and see if its an issue with the name not getting set correctly.
