adding/editing photos in Power CMS
Thread began 7/17/2017 8:33 am by kg_nsa395746 | Last modified 7/17/2017 2:45 pm by Ray Borduin | 406 views | 2 replies |
kg_nsa395746
I want to add Power CMS to a photo gallery. How is the best way to add the code? Include a separate region for each photo? The gallery will be responsive with Bootstrap div rows and columns. Is there a capability to limit the photo to a specified size? It appears that the default image insert option provides the capability to specify the size during the insert process. I'm thinking of how to keep the user from doing anything to destroy the design.
I'd probably implement it as template in power CMS so that images can be added and removed. Then I'd probably incorporate webassist's Image Resizer server behavior to resize images that are too large and add CSS to prevent it from messing up the display.
I could help with these things in a premier support ticket since getting it all working together properly can be rather difficult.
kg_nsa395746
Thank you Ray. I am in the pre-design phase but will definitely be reaching out to you with a Premium Support ticket when the photo gallery page is ready to set up.
I appreciate your excellent service and quick responses to my tickets. I have Power CMS installed on a number of my client websites and none of them have any problems interfacing with the dashboard and making edits. There is a fast learning curve for everyone with little technical support required of me.
