Hi Ray,
OK, I'm getting a bit frustrated at the output of Data Bridge, I've been messing with this for hours and still have no resolution. Here is the latest: I re-installed the extension, deleted any previously created files, went back through the dialog boxes to create Search, Results, Detail, and Update pages. Now when I submit a search I get a different message "Parse error: syntax error, unexpected '}'". When I look at the code produced it shows errors at lines 431, 458 and 589. The code does not seem to make sense, I see the two "}" braces but they don't seem to be closing anything, also there are <td> tags and a </table> tag but no starting table tag (lines 431 - 444). I have not done anything to the code I'm submitting so you can see for yourself. It seems something is amiss with Databridge. This shouldn't be this much brain damage.
Tom
