Is it an option to generate mysqli code rather than PDO code?
I am used to the mysqli format and not the PDO format. I just purchased WebAssist and I am lost looking at the code. Is there a solution?
The code is MySQLi not PDO... however the code you see on the page is our wrapper class. You can see the actual code called in the queryobj.php and rsobj.php file where the webassist classes are defined.
