https error
Thread begun 7/12/2017 2:16 pm by kg_nsa395746 | Last modified 6/01/2018 9:47 am by Ray Borduin | 3572 views | 8 replies |
kg_nsa395746
https error
I have installed SSL on a client's website and now when we attempt to browse to upload a file, we get an unsecure warning and have to click a browser link to ignore the warning. I don't know if this is an SSL issue or a Power CMS issue. Just searching for a resolution. Look at the attachments 1-4 for the progression to the error.
I think there are some script files on that index.php page that use http... you could go into that file and update them to use https:// for anything with a src="http:// and that would fix the problem.
kg_nsa395746
Thanks Ray, I can make the edits.
kg_nsa395746
https error
See private message.
This is an easy fix. If you give me a url to reproduce the problem and FTP access to the site I can fix it free of charge.
kg_nsa395746
See private message
kg_nsa395746
See private message
open the file:
webassist/kfm/index.html
Then find these lines:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.7.2/jquery-ui.min.js"></script>
update them to:
<script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
<script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/jqueryui/1.7.2/jquery-ui.min.js"></script>
kg_nsa395746
Ray, I wanted to let you know that the code edit you provided took care of the http error. Thank you for your help. Always appreciated.
