Coupons from database issues
Thread begun 9/07/2009 12:23 pm by bec341098 | Last modified 9/09/2009 1:13 pm by Jason Byrnes | 4181 views | 3 replies |
bec341098
Hi there, I am trying to implement coupons using values from a recordset, and things are going wonky. First of all, I went through all of the documentation and the forum, and although I think I followed everything to a T, the discounts are not being applied, and my cart.php page is no longer showing subtotal, discount or grand total.
After trying a few more things, I got these errors:
Notice: Undefined variable: row_rsCouponFlat in /shop/cart.php on line 20
Notice: Undefined variable: row_rsCouponFlat in /shop/cart.php on line 32
Notice: Undefined variable: row_rsCouponFlat in /shop/cart.php on line 38
Notice: Undefined index: CouponData in /WA_eCart/CedarChest_PHP.php on line 131
The recordset is there, so I have no idea why it would be returning those errors.
When I tested everything using a coupon and code using the "static" way of doing things, it worked just fine.
Does anyone have any advice?
Thanks much, and happy Labor Day!
-bec.
The error suggests that the code for the recordset is on the page after the lines generating the errors.
Make sure the recordset code is before the the other code that uses the recordset information.
bec341098
Hi Jason,
That took care of the errors other than the last two, and the last two were actually an error on my part. However, the cart subtotal/discount/grand total are still not displaying, and the discount is not getting applied!
Thanks,
-bec.
Please post a link to your site so I can look into the problem.
Here are the basic steps for setting up database driven promocodes:
First off, you should follow the solution recipe for static coupon codes to get coupon codes working. That tutorial can be found In the Solution Recipes section of the eCart Support Page titled "Creating a Coupon system for your eCart store":
ecart/
To convert that to be database driven:
1) Create a table in your database to hold the coupon codes. it should have a structure similar to:
couuponID - Auto Number, Primary key Column.
couponCode - varchar
couponAmount - double
To add a coupon code of "test" that will give a 10% discount, you would create the follwoing record:
couponID | couponCode | couponAmount
1 | test | 0.10
2) Next is to add a recordset to the page to lookup the coupon amount based on the code the user enters.
On the server behaviors panel, click the plus button and select Recordset. In Simple view, set the record set to use the coupon table we created. Set the name of the recordset to "rsCoupon" In the Filtering Section, set it to filter the couponCode column Equal to the Form Variable txtPromoCode, this is name of the text box created in the coupon code system tutorial.
3) Now we need to create another session variable to hold the discount amount. On the server behaviors panel, click the plus button and select eCart -> General -> Set Session Value. Set the trigger to "recordset rsCoupon Not Empty". Set the name of the session variable to "PromoAmount". Click the lightning bolt next to value, expand the rsCoupon recordset and select the couponAmount column.
4) The PromoCode session variable needs to be modified as well. Set the trigger to "recordset rsCoupon Not Empty" so it will only get set if the promcode sexists in the database.
5) The last step is to modify the Promotional Discount rule in eCart. Remove the "If Session variable == WebAssist" triger.
Add a new trigger "Session variable exists "PromoCode""
Add another trigger "Session variable exists "PromoAmount""
Then Modify the charge rule "Bases on Cart SubTotal "Times" "$_SESSION['PromoAmount']"
so that the discount will use the value stored in the session variable from the database.
