Failing to Load MySql Databases when crerating new DB Connection
Thread begun 6/26/2017 3:01 pm by Paul | Last modified 6/26/2017 5:36 pm by Ray Borduin | 1226 views | 1 replies |
PaulBeta Tester
Using CC 2017 with MySqli installed using DMXZone Ext Mgr. MAMP Pro 4.0 running MySQL to run on a specific port ID
When attempting to create a new connection, the wizard fails to load my MySQL databases to select - as per screenshot.
Any ideas?
This is usually because the Server URL setting for the Testing Server in your Dreamweaver site definition is set wrong. Copy and paste the value you have entered into your browser and make sure that it loads the site properly. Also make sure that if you are using .htaccess to redirect to https:// that the testing server url begins with https://.
