I would like to create a search that allows my subscribers to search by price ranges.
Thread begun 6/21/2017 5:18 pm by Daniel | Last modified 6/24/2017 12:18 pm by Ray Borduin | 4928 views | 14 replies |
Daniel
I've created a search parameter with drop down menus that allows a search of price ranges. I have two fields that have prices in them "costoutdor" and "costindor". They are currently set to "No Space Fee" "$25.00 or less" " "$50.00 or less" etc for each field. And then I've set the results page to provide for that search. What I would like to do is to be able to exclude shows that have a 0.00 dollar amount. The way that should work is that if I set the "$25.00 or less" or whatever the amount it should actually be "$25.00 or less (but greater than 1.00)" When I select "No Space Fee" it should then exclude all shows with any amount.
As an example, if I were to set the "Cost Indoor" to "$25.00 or less" and set the "Cost Outdoor" to "No Space Fee" then I should see results where the indoor fee is greater than $1.00 but equal to or less than $25.00. I shouldn't see any outdoor only shows. And of course the reverse should be true if I were to set the "Cost Outdoor" to "$25.00 of less" and set the "Cost Indoor" to "No Space Fee" then I should see results there the outdoor fee is grater than $1.00 but equal to or less that $25.00. I would want the other selections to reflect a similar response.
I've included the pages as attachments here and I'd appreciate your help accomplishing that!
You never want the search to return free shows? If that is the case then you can just add WHERE PRICE > 0 to the recordset directly on the results page.
Daniel
That didn't seem to work... but maybe I put the conditional statement in the wrong place
What I wanted to accomplish was that if the subscriber didn't select anything then of course all shows are returned. If they were to select "No Space Fee" for the outdoor shows and for example "$50.00 or less" for the indoor shows what would be returned in the results page would be only those shows with an indoor fee greater than $1.00 and equal to or less than $50.00. The shows with 0.00 for the indoor fee and 0.00 for the outdoor fee would be excluded from the results page. Of course the same would go for the reverse selecting "No Space Fee" for the indoor show shows would exclude all indoor only shows and limit the results to outdoor shows with a fee => $1.00 and ,= $50.00. Am I thinking correctly?
I see. That would require a little bit of hand coding. Try adding this after line 56.
if (isset($_GET['costoutdor']) && $_GET['costoutdor']) {
  $WADbSearch1->addComparison("costoutdor","1","AND",">=",1);
if (isset($_GET['costindor']) && $_GET['costindor']) {
  $WADbSearch1->addComparison("costindor","1","AND",">=",1);
Daniel
Didn't work
I inserted that code after Line 56 and when I ran the search it had no content on the results page
What does it say if you add this after:
echo($WADbSearch1->whereClause);
That should show the resulting where clause and could help me figure out where I went wrong.
Daniel
I'll be back in about two hours
Hello Ray... I'll try it as soon as I get back. I've got to go to an appointment in a few minute.
Daniel
I had a couple of minutes so I thought I'd give your clause a try... Here is what I got
AND (showbegin >= "2017-06-22 00:00:00") AND (costoutdor <= '0') AND (costindor <= '200') AND (costoutdor >= 1) AND (costindor >= 1)
Daniel
Did you get the response from the code
Hi Ray... were you able to decipher anything from the code that echo statement returned?
Dan
I updated the code. Try the new version.
