Other Currency
I want to be able tp use the Israeli (NIS) currency. Please if anyone can give me a step by step help on how to set it. I have the eCart6.
Thank you.
Thank you.
The steps are the same. The issue is that paypal and authorize.net don't support that currency, so you will have to identify a payment provider you can use and integrate it into the checkout process. I'd probably use authorize.net as the payment provider in the checkout wizard and then swap out the code at the end. We could help with that in a premium support ticket. Integrating a new payment gateway can usually be done in 1-2 hours.
