Form not submitting
I'm getting an error on my form at the end of my URL once it is submitted that says "?invalid=true"
Can you help?
Can you help?
That means it is failing the Server Validation on the page. Maybe you removed a form element but didn't remove the validation that makes it required. I'd have to see the page to debug it further.
I need an attached copy of the page itself. I can't see the server validation through a browser.
Your issue is probably on the plugins/comments.php page. I'll need to see that.
Try updating line 14 to:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["fieldset_group_4_Security_Question_2"])?$_POST["fieldset_group_4_Security_Question_2"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,4);
it looks like the session variable reference is wrong currently. I'll have to look into why that would happen.
Well, I don't get the error anymore. However, the email isn't going through.
The email code is in: /webassist/email/waue_comments_1.php
I may be able to spot the issue if I had a copy of that file.
