I use wampserver version 3.0.0 and mysql 5.7.9 and i just started having problems using dataassist
Thread began 6/05/2017 8:15 pm by JBWebWorks | Last modified 6/06/2017 12:40 pm by Ray Borduin | 1028 views | 2 replies |
JBWebWorks
The problem just started this week where I can't get any connection to find the database on my local wamp server.
I have tried a mysqli connection also and will not connect and shows 'an unexpected error occurred'
I have tried to login to phpMyAdmin and it will not login now. I've tried stopping and restarting wamp but still no luck.
Any suggestions?
If you can't log into phpMyAdmin then you issue isn't with Dreamweaver or DataAssist. It is an issue with your WAMP installation. You might want to try uninstalling and reinstalling WAMP. If you can't access your database from WAMP and phpMyAdmin, then you definitely won't be able to access it through Dreamweaver.
JBWebWorks
Thanks Ray. That was the problem.
I somehow had lost or changed my permissions with MySQL on the wamp server.
I ran FLUSH PERMISSIONS on MySQL console and that solved my problem.
