MySQLi Login User is wiping session variable
Thread begun 5/25/2017 9:28 am by Nathon Jones Web Design | Last modified 5/25/2017 12:37 pm by Ray Borduin | 1189 views | 1 replies |
Does using MySQLi Login User wipe any session variables?
Scenario...
Page 1 - a form that ask for a selection from a drop down menu - user submits
Page 2 - before page load session which stores the selection from the drop down menu, plus a MySQLi Login User behaviour
Page 2 - user is logged in but the session variable is wiped
Stuck, again, on something which genuinely seems really simple.
Having a very bad today, sorry.
NJ
You should use the POST value you are storing as a trigger for saving the SESSION variables... so on the login page line 6 you should have:
if(isset($_POST["numberoftickets"])) {
$_SESSION["tics"] = "".((isset($_POST["numberoftickets"]))?$_POST["numberoftickets"]:"") ."";
"before page load" happens twice. Once when the page loads, and once more when you submit the login form. The second time is when it gets cleared.
