Relational table insert, only if one of checkbox is ticked
Thread begun 5/18/2017 2:09 pm by Kumel | Last modified 5/22/2017 1:23 pm by Ray Borduin | 2794 views | 6 replies |
Kumel
i have added relational table behaviour to a page. On clicking submit all records are submitted irrespective of certain selection ie. radio boxes.
So i want those records to be added when one of the radio is ticked.
Screenshot added.
So whenever any radio is ticked for each row then it must enter data.
So if i have ticked only one radio then 1 record must be entered not the rest
Can I see a copy of the page? It should be possible, but I'd have to look at how your form elements are named and how you have it applied to comment on what to change.
Kumel
file attached..
1386 line:
<p>
<label>
<input <?php if (!(strcmp($row_QuestionTextArea['SAType'],"C"))) {echo "checked=\"checked\"";} ?> type="radio" name="SAType_<?php echo $RepeatSelectionCounter_4; ?>" value="C" id="SAType_0_<?php echo $RepeatSelectionCounter_4; ?>" />
Clear</label>
<label>
<input <?php if (!(strcmp($row_QuestionTextArea['SAType'],"P"))) {echo "checked=\"checked\"";} ?> type="radio" name="SAType_<?php echo $RepeatSelectionCounter_4; ?>" value="P" id="SAType_1_<?php echo $RepeatSelectionCounter_4; ?>" />
Pending</label>
<label>
<input <?php if (!(strcmp($row_QuestionTextArea['SAType'],"D"))) {echo "checked=\"checked\"";} ?> type="radio" name="SAType_<?php echo $RepeatSelectionCounter_4; ?>" value="D" id="SAType_2_<?php echo $RepeatSelectionCounter_4; ?>" />
Deviate</label>
</p>
Its related relational codes : Line 200:
// WA DataAssist Manage Relational Table 2
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) // Trigger
$WA_arrayOrFieldList = 1;
$WA_joinLoopedField = "SAQASID";
$WA_loopedField = "WADA_RepeatID_QASID";
I think you can probably manually add some code to do this on line 237.
I think you can update it to:
if (WA_AB_checkLoopedFieldsNotBlank(array("SAType"), $WA_mrtLoopCounter) && WA_AB_checkLoopedFieldsNotBlank(array($WA_joinLoopedField), $WA_mrtLoopCounter) && WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) == WA_AB_getLoopedFieldValue($WA_joinLoopedField, $WA_mrtLoopCounter)) {
Kumel
Parse error: syntax error, unexpected $end in /home/content/39/10368039/html/webgen/infideal/admin/be-application-details.php on line 1869...
I had made some changes in page all this time so lines might have changed.
My new file is attached here. Can you refer to me with this?
It looks like you updated code on line 1388 when I said to update line 237.
Change that line back to what it was.
You should just be updating line 237 from:
if (WA_AB_checkLoopedFieldsNotBlank(array($WA_joinLoopedField), $WA_mrtLoopCounter) && WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) == WA_AB_getLoopedFieldValue($WA_joinLoopedField, $WA_mrtLoopCounter)) {
Kumel
it works. thanks a lot. You saved me from mess up!
