mySQLi module not installed error after upgrading to PHP 7.1
Thread begun 5/12/2017 9:50 am by LionsMane | Last modified 5/12/2017 11:57 am by Ray Borduin | 2691 views | 8 replies |
LionsMane
apparently others are having this same problem. I upgraded my hosting to a new VPS supporting multiple versions of PHP, and as long as I'm using 5.6, my mySQLi functions work fine. As soon as I switch to 7.1, my DW functions fail with the well-known error: "Your PHP server doesn't have the MySQL or MySQLi module loaded or you can't use the mysql_(p)connect functions."
Have you found a solution to this yet? I modified the .js file someone else did, but that didn't help. Other thoughts? My Skype username is 'lionsmane'
Can you send me your ftp information and url? I'll test and see what I can find.
Have you updated to the latest version of the MySQLi Server Behaviors? We have made updates to correct this issue in the past.
LionsMane
Info
FTP info below
I need the website url as well for the connection.
LionsMane
URL
I'm able to connect to the database without issue using that connection. Try reinstalling the MySQLi Server Behaviors extension and make sure your site definition testing server is set up correctly.
LionsMane
Try again
yes, that's because I had the site using v6.5 and not the problem version 7.1 I've changed that over.. please test again.
I'm still able to connect to the database without issues with the latest version.
LionsMane
Me too
OK very strange. Now I'm able to create a connection in DW as well. I wonder if after making the .js change, I just needed to let things re-find themselves for it to work? Not sure.. sorry about taking your time.
