Timestamp Calculations
Thread begun 9/07/2009 7:52 am by Kevin373660 | Last modified 9/10/2009 12:29 pm by Kevin373660 | 7833 views | 7 replies |
Kevin373660
I am using DataAssist and eCart to handle a user pass renewal system with php and MySQL. I am stuck with calculating dates and need some direction from a fellow member of the forum. I have been echoing the values on screen simply for testing purposes so that I can verify my math before doing the record update. My understanding is that using TimeStamp the dates are stored in seconds.
I need to be able to:
1) Calculate the new Expiry Date (in a format ready for record update to db schema table) NewActivationDate=TodaysDate+(NewPassLength+RemainingPassLength)
2) Calculate the days remaining in a Pass (display as whole number on screen for user)
After doing the calculations, I know how to do the update using DataAssist record update server behavior. That part is easy, allows additional control with session variables that the standard update record behavior does not have and it works.
With this code:
echo $row_WAATKtblmembers['passActivation'];
echo $row_WAATKtblmembers['passExpireDate'];
echo strtotime($row_WAATKtblmembers['passActivation']), "\n";
echo strtotime($row_WAATKtblmembers['passExpireDate']), "\n";
echo $_SESSION['ActivationPassLength'];
Outputs to screen the following:
2009-09-01 00:00:00
2009-09-10 00:00:00
1251777600
1252555200
6
However, a simple math calc:
$datetoday = $_SERVER['REQUEST_TIME'];
$passExpireDate = $row_WAATKtblmembers['passExpireDate'];
$passDaysRemaining = ($passExpireDate - $datetoday);
echo $passDaysRemaining;
I expected a positive value like 777600 however, it Outputs to screen the following negative value: -1252332020
DarylBeta Tester
Try having a look at a question that I asked about calculating a persons age from date of birth as it might help.... (it might not)
http://www.webassist.com/forums/showthread.php?t=1886
Don't look at my solution, but try the one at the bottom of the thread by the WA gurus.
Kevin373660
Thank you Daryl for replying to my post. It has part of the puzzle. I miss the days when everyone in the programming community help each other. I first searched the forum for clues and had found your thread.
Perhaps is it just the stress that I am under, but I have not found a clear and accurate document or book that puts everything together. I have looked at php.net and mysql.com but I still don’t clearly see the whole picture. My application involves using the timestamp values from the db schema in mathematical formulas, updating mysql timestamp columns with results and echoing some of the results for the users. From what I have read this involves seconds, integers and converting data formats. On the web there seems to be a lot of inaccurate examples and disinformation. Hopefully, others in the forum that have run into this or the WA gurus, which have been so helpful before, can help clarify this for me and for other members.
There is another useful Webassist link php-scripts/ with a code script to Format Dates.
Functions used:
datediff
strtotime
abs
floor
***** Current Test Code Results ****
?><br />
MATH FUNCTION TEST AREA DAYS LEFT 2:<br />
$passActivationDate = $row_WAATKtblmembers['passActivationDate'];
$seconds = abs(strtotime($passExpireDate) - strtotime($passActivationDate));
$passDaysLeft = floor($seconds);
echo $passDaysLeft;
Screen Display:
TEST CODE:
1251777600 1252555200
1252419760
1252555200
Justin Nemeth
Are you storing dates in MySQL using their timestamp column type? If so, that might be what is causing some confusion. A MySQL timestamp is not the same as a php timestamp. The conventional timestamp (aka unix timestamp) is a number of seconds. MySQL stores something else which is harder to work with in php.
So, assuming you are indeed using the MySQL timestamp, I would use the MySQL UNIX_TIMSTAMP() function to have your query return a php timestamp. Then using the date() and strtotime() functions with the php timestamp should get you going on the right track. strtotime() is one of the most versatile functions for manipulating dates.
-justin
Kevin373660
Thank you Justin for your comments. Yes, I am using MySQL with the column datatype set to timestamp. So the #1 step is to convert the column info into a workable format, #2 do the math, #3 then convert result back into the correct format to update the table.
I have used DataAssist and SecurityAssist to query, authenticate and update the tables with multiple (6 to 27) columns with only 2 or 3 columns using the timestamp datatype.
$row_WAATKtblMySql['passExpireDate'];
How would I use the MySQL UNIX_TIMSTAMP() function to have the query return a php timestamp? Or should I just change the format within the code?
I found this example but I can&#8217;t get it to work.
<?PHP
// converts $unix_timestamp to "normal" formated_datetime:
$formated_datetime = DATE("Y-m-d H:i:s",$unix_timestamp);
// produces a timestamp that looks like "YYYY-MM-DD 24:00:00":
$formated_datetime = DATE("Y-m-d H:i:s");
// takes $formated_datetime and converts to "UNIX timestamp":
$unix_timestamp = STRTOTIME($formated_datetime);
Kevin373660
I figured out how to bring the unix_timestamp format in to the php format as code below. This was complicated because one of the passActivationDate column which also uses the timestamp datatype did not seem to need conversion from the Unix format. Does anyone know why this may have occured?
Is is related to the method that the data is entered? Through an update or directly on the table through my GUI using Navicat.
I am working on the math calc's. To update the table schema I am assuming that I need to convert the values? Then run the DataAssist update with those properly formated values. Is this the correct way to go from php timestamp to mysql timestamp?
<?PHP
$newExpiryDate_MySQL = strtotime("$newExpiryDate");
Justin Nemeth
In your SQL query, you could also do something like this:
SELECT UNIX_TIMESTAMP(passExpireDate) AS pass_timestamp ....
That would convert the MySQL timestamp column into a more php friendly unix timestamp.
Kevin373660
For the benifit of other forum members, this is what I found to work. You can use the $newExpiryDate_MySQL in your MySQL record update/insert.
//CONVERT NEW PASS EXPIRY DATE $newExpiryDate_MySQL
$newExpiryDate_MySQL = date("Y-m-d H:i:s", $newExpiryDate);
//echo $newExpiryDate_MySQL
