WA server validations: check if more than 15 days are passed from inserted date
Thread begun 5/09/2017 8:07 am by tony | Last modified 5/12/2017 7:16 am by Ray Borduin | 4007 views | 9 replies |
tony
Hi all,
I have a form with a date field where the user picks up a date.
I need to check if more than 15 days are passed from this date.
But I cannot find the right syntax in the WA server valkidation behaviour.
This is the server variable:
((isset($_POST["data_scontrino_reg"]))?date('Y-m-d',strtotime(str_replace("/","-",$_POST["data_scontrino_reg"]))):"")
and this is the MAX Date I specified in the related dialog box (using the yyyy-mm-dd setting):
<?php echo (date($_POST["data_scontrino_reg"],strtotime('+15 day'))); ?>
But it doesn't seem to work.
What am I doing wrong?
TIA
tony
If you want to restrict the date to be less than 15 days in the future, then Max date would be something like:
<?php echo (date('m/d/Y',strtotime($_POST["data_scontrino_reg"],'+15 day'))); ?>
tony
Hi Ray,
I tried your code but it doesn't work.
I changed it to:
<?php echo (date('Y-m-d',strtotime($_POST["data_scontrino_reg"],'+15 day'))); ?>
but it doesn't work too.
What else can I do?
Michael
This post has been deleted.
Sorry I didn't think that through properly. That would restrict the date to be less than 15 days from itself. To set the max date to be 15 days from today the max date should just be:
<?php echo(date('m/d/Y',strtotime('+15 day'))); ?>
tony
Hi Ray,
I think I haven't posted my question the right way.
I need to validate the date inserted checking if it is more than 15 days old.
Example:
today is 10 may 2017.
If the user enters the date 10 april 2017: date invalid;
If the user enters the date 5 may 2017: date valid.
I tried this:
TIA
tony
In that case I think you want to set the Min Date to:
<?php echo (date('Y-m-d',strtotime($_POST["data_scontrino_reg"],'-15 day'))); ?>
tony
Hy Ray,
thanks for your reply.
What is the difference between:
- SET MAX DATE: <?php echo (date('Y-m-d',strtotime($_POST["data_scontrino_reg"],'+15 day'))); ?>
and
- SET MIN DATE: <?php echo (date('Y-m-d',strtotime($_POST["data_scontrino_reg"],'-15 day'))); ?>
Thay seems doing the same thing.
But I can be (easily) wrong. ;)
TIA
tony
Maximum date would allow any date before that to be entered.
Minimum date won't allow any date before it has to be after.
tony
SOLVED:
I was making a big mistake: I was checking a date field (data_scontrino_reg) against itself using:
as MIN DATE.
So, it was always failing.
But I need to check it against the current date, so I used:
<?php echo (date('Y-m-d',strtotime('-15 day'))); ?>
and it works.
Sorry for making this confusion.
Tony
