Authorize.net - Disabling TLS 1.0 and TLS 1.1 does it cause any issue to eCart?
Thread begun 5/03/2017 3:36 pm by ccdantas101117 | Last modified 5/05/2017 9:26 am by Ray Borduin | 1904 views | 3 replies |
ccdantas101117
Does this from authorize.net cause any problem to eCart?
Dear Authorize.Net Merchant:
As you may be aware, new PCI DSS requirements state that all payment systems must disable early TLS by 2018. Transport Layer Security (TLS), is a technology used to encrypt sensitive information sent via the Internet. TLS is the replacement for Secure Sockets Layer (SSL).
In preparation for this requirement, Authorize.Net plans to disable TLS 1.0 and TLS 1.1 on the following dates:
Sandbox: COMPLETE
Production: September 18, 2017
We have disabled the sandbox in advance of production to allow you and your developer time to test your website or payment solution and ensure you are no longer using TLS 1.0 or 1.1 prior to September 18th.
Please contact your web developer or payment solution provider, as well as your web hosting company, to confirm that they can support TLS 1.2 for your API connections.
Your hosting provider has likely already taken care of this for you.
In order to test, create a blank page on your server with this code:
$ch
curl_init('https://www.howsmyssl.com/a/check');
curl_setopt($chCURLOPT_RETURNTRANSFERtrue);
$data curl_exec($ch);
curl_close($ch);
$json json_decode($data);
echo
$json->tls_version;
That will tell you the TLS version installed. If it returns 1.2 you are all set, otherwise contact your hosting provider to get it updated.
Supreme Geek
TLS 1.2 test code
Ray,
I created a blank PHP page and inserted your code. When I tried to view it online it just gave me the original code. Here's my page: http://lotcs.org/TLStest.php. Is there something that I'm doing wrong? Thanks in advance...
Dale
You pasted it in Design View and Dreamweaver automatically encoded it to display it on the page rather than run the code.
Paste it in Code View and it should run.
