Making a text into textfield using summernote js
Thread begun 5/01/2017 11:39 am by Kumel | Last modified 5/01/2017 12:47 pm by Ray Borduin | 1431 views | 1 replies |
Kumel
So i kinda have a master page created which displays almost entire details of the application.
This are display in table like image attached.
Currently there is no form or textfield or hidden field.
Its just plane text from db.
I want to make these into textfield/textarea but display as it is & should be able to edit them.
I found a way here: http://summernote.org/examples/
Using summernote air mode it can be accomplished but i m not able to use for updating these records.
How can i make this work?
FYI, Following is js :
$('.summernote').summernote({
airMode: true
so making input class="summernote" display textfield as well.
But if i use on div class="summernote" display & can be written as well.
I'm not that familiar with summernote. You would have to use a premier support ticket to get help with something like this since it would take some research and testing to pull off.
