International Shipping - checkout form is validating state field for an entry
Thread begun 4/27/2017 8:52 am by cal114936 | Last modified 4/28/2017 8:39 am by Ray Borduin | 3964 views | 9 replies |
cal114936Beta Tester
To ship international, the checkout form is validating if there is a value for a state even if the country doesn't have states. How can this validation be changed to allow a blank entry for countries without states? It is already hiding the US States drop down and replacing it with a text field.
Please attach a copy of the confirm_cart.php page and I can instruct you on what code needs to be changed.
The file is attached
You could replace line 32 with:
$WAFV_Errors .= WAValidateRQ((($_POST["Country"] == "US")?$_POST["State"]:"n/a") . "",true,7);
and line 42 with:
$WAFV_Errors .= WAValidateRQ((($_POST["Country_2"] == "US")?$_POST["State_2"]:"n/a") . "",true,16);
Then it would only validate the State if the country was set to "US"
It works.. sorta. The changes allowed the blank entry in the state field. But if you have to make a change to the address and go back to the form it won't take the input any input unless you enter a state.
Also if I choose PalPay in Payment Options it won't open the window.
I'll need the url to the page to debug that.
See PM
I'll need FTP access to debug it. It appears to be an issue with the validation script that isn't running, but I'm not sure what might have caused it.
It may be a conflict with the multiple jquery versions you have on the page.
See PM
The error is in the custom code you have on lines 95-114... If I remove that the page works properly.
It looks like the referenced objects: smallAd2, and fixedAd2 don't exist on this page. So you probably just have to delete lines 99-108
