mysqli update not working properly
Thread began 4/26/2017 11:50 am by Ashok | Last modified 5/02/2017 2:42 pm by Ray Borduin | 2615 views | 14 replies |
Ashok
Hello,
I have this page http://бимпра.рф/admin/updatetour.php?id=1 with multiple text area. Now if i fill proper data (not just ggggggg) in many fields, nothing is saved in database. Trying to save data in inclusions and exclusions textarea but it is not saved in db.
I'd need to see the page to see why it might not work.
Ashok
do you need ftp as well?
Please attach the page instead of copy/paste... I want to open it with Dreamweaver.
Try adding this after the $UpdateQuery->->execute() on line 191:
var_dump($UpdateQuery);
die();
That could give more information about why it is failing. There are no obvious problems I can see.
Ashok
I have added that line.
File is attached.
updatetour.php
Try changing the <button> into <input type="submit" instead. Does that fix it?
Ashok
That didn't helped.
I think it is related to mysql error #1118. Didn't found any solution yet.
DB dump is attached. Do you get mysql error as well?
ivpuhxpn_bimpranewru.sql
Do you see the dump on the page after adding the code I suggested?
Can I get FTP access and a URL to reproduce?
Ashok
Yes, I can see the dump.
FTP attached.
OK I see the error. It is a row size error in mysql as you suggested earlier, error: 1118
Here is a thread that appears to have several suggestions for how it might be fixed.
http://stackoverflow.com/questions/22637733/mysql-error-code-1118-row-size-too-large-8126-changing-some-columns-to-te
Your page is fine, it is going to mean making changes to the database or php.ini file not the update code itself.
