Using a MySQLi recordset as recipient addresses
Thread begun 4/26/2017 7:43 am by Steve_UK | Last modified 4/26/2017 2:03 pm by Ray Borduin | 2726 views | 5 replies |
Steve_UK
Ray
I know that there is a post on your site from Jason stating that you were targeting the first quarter of 2015 for a release of a Databridge/MySQLi integration - is there any news on that please now that we are 2 years on?
Not withstanding that, I am trying to use a MySQLi recordset manually to send out an email which does not seem to fire.
Here's my attempt - can you advise whether or not this should do the job please?
I really don't want to go back to MySQL recordsets.
// Start build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
while(!$rsRecipients->atEnd()) {
$RecipArray[$CurIndex ][] = "".($rsRecipients->getColumnVal("user_username")) ."";
$rsRecipients->moveNext();
$rsRecipients->moveFirst();
$RecipArray[$CurIndex ][] = "user1@domain.co.uk";
$RecipArray[$CurIndex ][] = "user2@domain.co.uk";
// End build up recipients array
The recordset returns the required records just fine.
The email DOES land with user1 and user2.
Thank you
Steve
That should work. Are you sure the recordset is filtered correctly and that $rsRecipients->getColumnVal("user_username") returns an email address?
Steve_UK
Thanks for the reply Ray
I can drag the query out of Dreamweaver, substitute the '?' for the parameter, run it against the server and the list is returned perfectly.
Weird!
Steve
Do this:
var_dump($RecipArray[$CurIndex ]);
die();
See if all three email addresses are in the array.
Steve_UK
Ray
Thanks for that - it was a coding error after all but you pointed me in the right direction with the visibility of the array.
Any real news on the Databridge?
Regards
No meaningful updates. I'm glad it is working for you now.
