Dual image
Thread began 4/25/2017 10:21 pm by balexander389215 | Last modified 4/26/2017 12:09 pm by Ray Borduin | 668 views | 4 replies |
balexander389215
Dual image
I am using Power CMS Builder to upload text and images on a website. the text is fine but I seem to be getting a dual image. It's been a very long time since I've added images through cms so I'm not sure of the correct behavior.
On the Image Pooperties page I add teh URL as required. On the links page I again point to the same URL. If I don't do both the image does not appear. If I do both the when the page loads i get indications that two images are loading and it looks like the photo with a small image container above and the main image below.
The source code in for the image in the cms edit box is as follows:
<a href="/new2/files/annieweise.jpg"><img alt="Annie Wiese" src="/new2/files/annieweise.jpg" style="width: 300px; height: 352px;" /></a>
Is this normal behavior or am I doing something wrong in the image upload procedure. i have checked all the help files i can find on cms but cannot fine anything for uploading images.
Brian
The code looks correct. You might have javascript on the page that is automatically displaying images that are linked? If you give me a url where I can view the problem I may be able to tell you more. It doesn't appear to be an issue with what you are doing in the CMS or the code it produces.
balexander389215
Here is the URL to the page
https://www.awiesetherapy.com/new2/about_annie.php
Can I see a copy of the about_annie.php page? It looks like an issue with how you are adding the cms content on that page.
balexander389215
Somethng must have went wrong with the page because when I tried to open it in Dreamweaver it crashed DW. I rebuilt the page and now it works fine without a ghost image. I did notice that if I'm in cms builder and then open a new tab to view the pages the live edit function appears for the text, but not the image which does not load, just a spinning circle as it attempts to load. Is this normal?
Thanks for your input, much appreciated.
Brian
