BEWARE, latest dreamweaverCC update 4/19 renders binding inoperatable
Thread begun 4/23/2017 9:31 am by p_vouers282571 | Last modified 5/15/2017 4:25 pm by Ray Borduin | 4111 views | 10 replies |
p_vouers282571
Non of my extensions would allow me to select(in the wizard) binding fields. Deleted infilecashe, reinstalled extensions to no avail. Had to reinstal;l dreamweaverCC back to an earlier version then REINSTALL eveerything.
Thank you Adobe program writers--- fools!!
Yes it does appear to break bindings for both PC and Mac when accessed from within a command. Please report this to Adobe, if enough noise is made they may fix it.
p_vouers282571
reported it but Adobe is not customer orientated, more money orientated. Looks like a lot of people have been griping about server behaviors forever. It was a cold day in *ell when Macromedia sold to Adobe.
This one is a pretty big deal, so hopefully they will fix it. If they haven't in a few months then I suppose we can work on our own, but I'd rather focus on moving forward than backward, so let's hope they address it.
p_vouers282571
see pm
p_vouers282571
I use databridge, mysqli and ecart.. Will these all work on cs6 if I roll back to that version. Doesn't look like adobe is interested in solving the problem anytime soon.
Yes they all work on CS6
p_vouers282571
doesn't look like Adobe is going to address the issue, looks more like they point fingers at Webassist and praise dmxzone, and judging only frolast names wonder if they are owned by dmxzone or visa versa :-)
They aren't directly related to DMXZone, but it is their own interfaces that don't work, so I'm surprised they would point fingers at us. The issue exists without any of our extensions installed at all. It is an issue with the Bindings window and the create database window.
That is interesting. Maybe it does have something to do with our interfaces if that is what they are claiming. I'm going to do a clean install with just the Server Behaviors and Database extension installed and none of ours and see if the problem persists.
Well I just tried. I did a clean install with just the Server Behaviors and Database extension and no webassist extensions and the same problem occurs. So there is no way it could be "our" problem. When you report the issue to Adobe don't even mention webassist so they don't have a chance to deflect.
With just the server behaviors and database extension installed:
1) If you add a recordset and click the define connection button DW crashes
2) If you add a connection through the database panel then it works, but it doesn't ever show in the database panel (it will show in the recordset dialog and you will be able to create a recordset at this point)
3) In the advanced recordset dialog the tree control that allows you to build your query doesn't work. Clicking the Add to query or Where buttons do nothing.
4) If you try to add a binding to a form element it won't work. Add a form text field to the page. Go to the properties panel and click the lightning bolt. You won't be able to select anything from the bindings panel.
You don't need a webassist extension installed to reproduce any of these problems, so they really can't be related to us directly. Unfortunately we will probably have to fix the problem even though it isn't ours to begin with. We can create a new Database Panel and a new Bindings panel and rewrite out extensions to use ours instead of theirs now that it is broken. It just holds up our progress once again, which is the sad part.
p_vouers282571
ray see message
