mysqli insert not working after adding html editor
Thread begun 4/22/2017 11:51 am by Ashok | Last modified 4/25/2017 2:28 pm by Ray Borduin | 1513 views | 3 replies |
Ashok
Hello,
I have a form and mysqli database insert works fine.
As soon as I add html editor to textarea, mysqli insert doesn't works. Nothing is inserted in database.
Here is the textarea code.
<div class="form-group"> Программа День 1
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "No File Management";
$CKEditor_config["wa_preset_file"] = "NoFileManagement.xml";
$CKEditor_config["width"] = "100%";
$CKEditor_config["height"] = "200px";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("day1desc", $CKEditor_initialValue, $CKEditor_config);
</div>
I don't see how adding an html editor to the page would effect the insert. I'd need ftp information to debug the page to see why it is failing.
Ashok
Hello,
It is not working on my local server but working fine on remote sever. No idea though why it is not working locally :(
Unfortunately I can't debug an issue that only happens locally. It has to be differences in the connection file or database column names on your local and remote servers causing the issue. It can't be the html editor.
