bootstrap multiple select update records
Thread begun 4/21/2017 10:49 am by Kumel | Last modified 4/24/2017 11:59 am by Ray Borduin | 4975 views | 6 replies |
Kumel
I m using following js: https://silviomoreto.github.io/bootstrap-select/methods/
Following is my code:
<select class="selectpicker" name="pendingdocs" multiple>
do {
<option value="<?php echo $row_PendingDocTypes['DocumentTypeID']?>"<?php if (!(strcmp($row_PendingDocTypes['DocumentTypeID'], $row_ApplicationDetails['AppDocPending']))) {echo "selected=\"selected\"";} ?>><?php echo $row_PendingDocTypes['DocumentTypeName']?></option>
} while ($row_PendingDocTypes = mysql_fetch_assoc($PendingDocTypes));
$rows = mysql_num_rows($PendingDocTypes);
if($rows > 0) {
mysql_data_seek($PendingDocTypes, 0);
$row_PendingDocTypes = mysql_fetch_assoc($PendingDocTypes);
</select>
I added single update record behaviour for the same. So this is a multi select dropdown option.
When i select multiple options & click update only 1 gets updated & multiple ain't getting updated.
If i select multiple options as: one, two, three; i want it to store as one, two, three
file also attached.
To allow multiple selections in php you need to name your form element: name="pendingdocs[]" (with the brackets).
That will pass the selected values as an array.
How did you want them inserted? Comma-separated? That would be done by updating line 167 to:
$WA_fieldValuesStr = "Y" . $WA_AB_Split . "".((isset($_POST["pendingdocs"]))?implode(", ",$_POST["pendingdocs"]):"") ."";
Kumel
So it does update the data.. But i can't view it back on dropdown again.
I mean existing values aint displaying in dropdowns
You would have to use different code to re-select the values on the update page. What does the select list code look like on the update page currently?
Kumel
do {
<option value="<?php echo $row_PendingDocTypes['DocumentTypeName']?>"<?php if (!(strcmp($row_PendingDocTypes['DocumentTypeName'], $row_ApplicationDetails['AppDocPending']))) {echo "selected=\"selected\"";} ?>><?php echo $row_PendingDocTypes['DocumentTypeName']?></option>
if($rows > 0) {
You could try:
do {
<option value="<?php echo $row_PendingDocTypes['DocumentTypeName']?>"<?php if (strpos($row_ApplicationDetails['AppDocPending'], $row_PendingDocTypes['DocumentTypeName']) !== false) {echo "selected=\"selected\"";} ?>><?php echo $row_PendingDocTypes['DocumentTypeName']?></option>
} while ($row_PendingDocTypes mysql_fetch_assoc($PendingDocTypes));
$rows mysql_num_rows($PendingDocTypes);
if(
$rows 0) {
mysql_data_seek($PendingDocTypes0);
$row_PendingDocTypes mysql_fetch_assoc($PendingDocTypes);
Kumel
awesome.. thnks a lot
