forgot password server behaviour doesnt seem to work
Thread begun 4/13/2017 11:22 am by Christopher West | Last modified 4/19/2017 4:47 pm by Ray Borduin | 2652 views | 5 replies |
Hi I have attached the main php file and will also show the snippet of code here.
I have an email address in database and the lookup on my forgot password page doesnt seem to find the email address entered. is there something obvious from the code that I am missing/getting wrong?
if (isset($_POST["forgot"]) || isset($_POST["forgot_x"])) {
$CheckNew = new WA_MySQLi_Auth($ecartdb);
$CheckNew->Action = "checknew";
$CheckNew->Table = "users";
$CheckNew->addFilter("UserEmail", "!=", "s", "".((isset($_POST["email"]))?$_POST["email"]:"")  ."");
$FailedRedirect = "forgot-password.php?Alert=NoAccount";
  if (
function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$CheckNew->FailRedirect = $FailedRedirect;
$CheckNew->execute();
<form method="post" name="forgot" class="standard" id="forgot">
<label>Email Address</label>
<input name="email" type="email" required placeholder="Please provide your email address" title="Required" tabindex="1" autocomplete="off" pattern="[^@]+@[^@]+\.[a-zA-Z]{2,6}">
<button name="forgot">Send</button>
</form>
Regards
Chris
Your button doesn't have a value. Try triggering off the email field instead of the button.
I tried this and doesnt work. or do i have the trigger formatting wrong?
if (isset($_POST["email"]) || isset($_POST["email_x"])) {
What part isn't working? You have the "checknew" server behavior code pasted but you are talking about the forgot password email. Can I see the whole page? There are a few working parts and the issue may be in the code you haven't provided.
Hi Ray, I did originally attach the main php file when I started this post. the file is forgot-password.php - do you not see it in the first post I made ?
Chris
I see the attachment now. I must have missed it.
I don't think you can use the "check new username" in the way you have tried. Instead just add a recordset to the page filtered by the emial address and then manually add an IF statement that redirects if the email isn't found.
You would filter where the email = the entered value and then use an IF statement like:
if ($CheckRS->TotalRows == 0) {
header("location: forgot-password.php?Alert=NoAccount");
  die();
