Connection errors
Thread begun 9/06/2009 10:38 pm by jebrandon343719 | Last modified 9/08/2009 12:01 pm by Eric Mittman | 2168 views | 1 replies |
jebrandon343719
Connection errors
I just set up a login using Security assist. It works okay on my testing server, but like it is full of errors. This is my first one - when I try to sign in
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/wwwinsto/public_html/Connections/db_instone.php:13) in /home/wwwinsto/public_html/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/wwwinsto/public_html/Connections/db_instone.php:13) in /home/wwwinsto/public_html/WA_SecurityAssist/Helper_PHP.php on line 5
What is doing this
You can get this message if there is any white space outside of php script blocks on the page that is giving the error message. It is best to try and look at the source and remove any extra spaces or returns that are outside of the <?php ?> blocks.
This is also a problem that can happen if you select the option in Dreamweaver to Include Unicode Signature (BOM) On creating New pages or when saving, it is a PHP bug:
bug.php?id=22108
To fix the problem, Go to File -> Save As. In the Save As Dialogue box, uncheck the Include Unicode Signature (BOM) option.
You should make sure that this option is not set in Dreamweavers preferences as well.
Go to Edit -> Preferences, in the new Document section, uncheck the Include Unicode Signature (BOM) option.
Let us know how this goes for you.
