Activation Nightmare
Thread begun 9/06/2009 9:44 pm by bill303473 | Last modified 9/08/2009 6:06 pm by Eric Mittman | 3450 views | 3 replies |
bill303473
Since I rebuilt my system, every single time I go to use a WebAssit product, it is requiring me to activate. After a few cycles, it tells me I have too many activations and I have to reset ALL my product keys. What is going on? This is a nightmare. I've been using your stuff for a number of years and this has never happened before.
This type of repeat activation can occur for users that have a changing MAC or Physical Address for the primary connection.
To see if this is the problem for you please record your Mac address then the next time you are prompted for activation record this info again.
To find out the MAC address:
1) Go to the Start Menu -> Run. Type "cmd" and click on OK to bring up a command prompt.
2) At the command prompt type "ipconfig /all > c:\ipconfig.txt"
This will create a file in your C drive called ipconfig.txt. This file will have the MAC address in it.
Please record these values and compare them to see if it is changing for you. If this MAC address changes then you will be prompted for activation again. Please get back to us with the result.
bill303473
Activation Follow-up
Eric,
Thanks for responding. My MAC address has remained the same since 4 June when I built this box, it's 00-24-1D-17-B0-36. There is only one NIC in the box and I'm on a wired ethernet connection. I expected the activation refresh when I reloaded but not repeatedly.
Bill
I have opened a ticket for you on this issue. Please update the ticket by logging into WebAssist.com and visiting your support history. I need some additional details from you to continue.
