missing tables, dos settings
Thread begun 4/10/2017 9:50 am by Patrice | Last modified 4/10/2017 11:28 am by Ray Borduin | 1937 views | 3 replies |
PatriceWebAssist
missing tables, dns settings
I have a client who manages his own registrar. I built a site for him 8 years ago and he never needed any updates. Today, he requested some changes and I proceeded to create a new database, using DataAssist to create back end admin. However, I couldn't get it to link to any tables. Further investigation shows that the bindings are all not working on a page. Digging further I see that he changed the DNS settings inside of Network solutions to point to other servers. I am assuming he has some pointer to my server.
What do I need to do in order to get it working (besides asking him to reverse his DNS setup)? What settings can I ask him to get his email tech guys to do in order to make the site viable in DW again? Or what do I need to change on my server to work with his particular arrangement?
Thanks.
UPDATE: I opened a ticket with my server gods (I have a dedicated set up) and got this reply back:
Website : http://xxx.com/ is still resolving to your server's IP : xxxxx even though it uses remote nameservers. So any changes you make to files in folder "/home/xxxx/public_html" on your server will be reflected on the website. From file "Connections/xxx.php", I can see database used is : "xxx1" and it is still active.
As much as that is true, it still doesn't help me make the bindings, or use DA to create admin pages.
Anyone have any ideas?
I am looking for a server setting in cPanel to change or how to use the remote server instead of "localhost" in connections or in DA set up.
Thanks.
PatriceWebAssist
The error message, when opening older pages with tables able to be seen, when opening the binding, is "unidentified error"... just added information in case that helps.
I don't think you have to change anything in the DNS or control panel.
The issue is likely with your testing server settings within Dreamweaver.
PatriceWebAssist
ah... Brilliant. I hadn't touched this particular site for 8 years and changed externals. Thank you so much!
