security assist error
Thread begun 4/07/2017 11:59 am by larry268887 | Last modified 4/07/2017 12:26 pm by Ray Borduin | 1085 views | 1 replies |
larry268887
My computer crash and I'm reinstalling everything and the problem is that i'm getting this error: Notice: Undefined index: SecurityAssist_UserID in C:\xampp\htdocs\ElvisRemake\includes\header.php on line 7. I don't get this on the actual website so I believe there is something missing on my local computer.
I was wondering if you could tell from the error what is missing?
It is a notice, not an error... so it may be that you just have notices turned off on the actual website and displayed on your local computer.
You have a recordset: rsUsers defined on the top of the page that you aren't using, so you wouldn't notice if the notice was simply not displayed the page would display fine.
That recordset is filtered with a sesison variable that isn't defined. There is no code on the page requiring that the user be logged in before seeing this page, and the recordset depends on a session variable that is probably set in the login process.
The solution is either to simply delete that recordset from the page because you aren't using it, or to require login in order to view this page.
