Delete button not working on results page
Thread begun 3/30/2017 9:13 am by Mags | Last modified 3/30/2017 2:15 pm by Ray Borduin | 4268 views | 6 replies |
Mags
Hi Ray, having a problem with a DataAssist results page I just built, where the Delete record button isn't working - the popup appears, the Cancel button work but clicking Delete does nothing. I've tried the usual fixes with code order etc but can't get it to work. Could you take a look at the code for me? Page attached.
It looks like the delete record server behavior isn't applied on the page at all.
You can apply it manually to the page now pretty easily. Just use the "Delete" button press as the trigger and the "WADADeleteRecordID" form field as the value to delete.
Mags
Ah, I had tried moving the Delete Record behaviour above the Recordset instead of below, but looks like I may have removed it completely! I've put it back, but again it's not working, same issue as before - see updated attachment.
It looks like that should work. Do you have a URL where I can view it live? Perhaps I can spot the problem that way.
Mags
See PM.
The page is missing the jquery javascript files. You can probably just grab them from another page and add them to the head tag.
Mags
That's it working now, many thanks!
