Little Trash Can (function) won't delete the record on results page
Thread begun 3/29/2017 8:06 am by lr_leal239405 | Last modified 4/19/2017 3:30 pm by Ray Borduin | 2604 views | 6 replies |
lr_leal239405
I don't know why the trash can won't delete the record on results page. On the details page it works fine. The code on the results page is same exact as that I have on another client's, which works, but not on this client. What is preventing it from deleting? I have attached the file. The page is: http://www.enzoscucina.com/cmsadmin/cms_results.php. I've provided login on your private msg. Thank you.
It looks like it is having issues since your unique key isn't defined as a number column and has a lot of preceding zeros. It should fix it if you update line 348 and replace this:
document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAenzosevents['CMSID']); ?>;
with this:
document.getElementById('WADADeleteRecordID').value='<?php echo($row_WADAenzosevents['CMSID']); ?>';
lr_leal239405
Thanks Ray. I think the replace with is exactly the same as the one to replace. Maybe you pasted same inadvertently.
No the replace has single quotes around the ID value. That is the only difference.
lr_leal239405
Thanks for your help. It's been a while since I tried to resolve this. This never worked though. Even when I deleted the leading zeros and added the single quotes it still won't delete. ?
It looks like the delete record server behavior isn't even on the page. It would have to be added back through the server behaviors panel.
You can use the "Delete" button as the trigger and the value of the "WADADeleteRecordID" field as the lookup value to delete.
lr_leal239405
ok. it works now. Thanks again ! :)
