Keeping Formfield if captcha fails
Thread begun 3/27/2017 3:59 pm by p_vouers282571 | Last modified 3/28/2017 5:31 pm by john70964 | 2324 views | 4 replies |
p_vouers282571
Made a basic form with dreamweavercc forms, then added universalemail and topped off with a captcha. To keep the formfield entries if captcha fails I bound the individual fields to the associated name under bindings | Wa validated entries. That seems to make the entry stick. Did I do that right?? Also is the captcha that is inserted under forms case sensitive?
That all sounds correct. You can make the captcha case sensitive or not depending on how you apply the validation. If you attach a copy of the page I can tell you if it is case sensitive and how to toggle it.
p_vouers282571
ray sent you a pm
Yes that is case sensitive. To make it not case sensitive use:
$WAFV_Errors .= WAValidateLE(strtolower($_SESSION['captcha_Security_Code_1']) . "",(strtolower((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"")) . "",true,1);
p_vouers282571
thanks Ray,
for all your help
