Having a problem with two forms on one page
Thread begun 3/27/2017 10:46 am by russb335115 | Last modified 3/28/2017 2:56 pm by Ray Borduin | 1893 views | 4 replies |
russb335115
I'm having a problem with two forms that are on one page. The form works great by itself, however, once I put it into a template page with another form. The security function stops it from submitting.
See PM
The validation seems to be working on the page when I tried. Where exactly is the problem. What are the steps to reproduce? If it is an issue with the server validation I'll need a copy of the page to fully debug it.
It might be with the server side validation? For that just make sure your buttons are named uniquely and that you are using the associated "button pressed" trigger for the correct set of validations.
russb335115
Hi Ray,
There are two forms on this page. The one in the body copy and the one in the contact section at the bottom. The one in the body copy is the one not working. I keep getting that an error on the question when I submit.
See PM
When you have multiple security question fields on the page you have to set the: $questionVersion variable
I went through and set it on every page I could find a reference to the wavt_captchasecurityquestion.php page and made sure that the server validations used the correct number and it appears to work correctly now.
russb335115
Thanks Ray, looks like it working.
