Javascript errors with DW CS6 (Mysqli server behaviors) on Mac
Thread begun 3/24/2017 4:27 pm by dionysus224892 | Last modified 3/25/2017 12:00 pm by Ray Borduin | 1598 views | 2 replies |
dionysus224892
I was trying to populate a pull-down menu dynamically, when I got the following error :
—While executing applyServerBehavior in DynmicSelectList.htm, a javascript error occurred.
I tried disabling and re-enabling extensions, I got the other error :
—The DynamicSelectList script does not define the applyServerBehavior function.
Now I had a crash and recently reloaded everything. Brand new installation of CS6 and I have only 4 extensions loaded.
—Mysqli server behaviors 1.0.4
—WebAssist Free Tools 1.1.3
—eCart 6.1.1
—Design Extender 1.2.1
I tried deleting MacFileCache.dat etc but there were no cache files (probably because it's a recent installation). So these are the first 4 extensions I installed.
If you have any advice, it would be very useful about now. Thanks!
I think you may be looking in the wrong folder for the macfilecache if you haven't found it. It will always be there. It could be an issue with the specific page you are working on or the steps you are using. I'll need to reproduce the problem to debug it, but first let's make sure it isn't fixed by a simple macfilecache clear. What folder are you looking in?
dionysus224892
You're right, I was looking in the wrong place. I found it and deleted it after disabling all the extensions but mysqli server behaviors. It worked fine but when I re-enabled the other 3 extensions, the same error popped up:
I threw the new cached file again and it's now working. But I'm going to be keeping an eye on it for the next few hours.... thanks!
