Converting to MySQLi
Thread began 3/21/2017 12:36 pm by larry268887 | Last modified 3/21/2017 2:43 pm by Ray Borduin | 417 views | 1 replies |
larry268887
I have to lines that I'm not sure how they should be recoded. The two lines are:
$sql="UPDATE products SET ProdInv = '$newInv' , ProdAvail = '$newAvail' , RecOrder = '$newRecOrder' WHERE ProdId = '$newId'";
$result = MYSQL_QUERY($sql);
Could you tell me how to re code these two lines using MySQLi ?
Use the MySQLi server behavior for updating a record in the database to get the correct replacement code.
Bind the ProdInv column to <?php echo($neewInv); ?>
and so on for the other columns.
