CMS pages cannot be displayed
Thread began 3/20/2017 2:16 pm by Badger | Last modified 3/21/2017 2:44 pm by Ray Borduin | 415 views | 6 replies |
Badger
CMS Cannot find server and The page cannot be displayed
Running DWCS6 v12.0 on a PC with WA Data Brigde 1.2.3 and WA Design Extender 1,2.1 on http://villagefarm.eu
Trying to get a new site working with CMS but the Install Wizzard won't run after "Get Started!", I keep getting "Cannot find server" and "The page cannot be displayed"
All permissions are at 777 and the ISP say Session Support is enabled
Is this a root problem, PHP version, Safe Mode or something else?
Best
Badger
I'd have to look into it. Sounds like an issue with session support, but if you give me a url and FTP access I'll debug it and let you know.
Badger
Hi Ray, Thanks for the quick reply. Server guys say session support is okay. Below is the ftp info. Thanks.
What is the url to see the error?
I was able to figure out the correct url.
The issue appears to be a problem with CURL connecting to secured sites. I can connect to http://www.webassist.com through your server, but it fails with a hard error like you see when I try to connect to https://www.webassist.com
Please ask your hosting company to debug the CURL installation and its ability to connect to sites secured with SSL and they should be able to fix it. Let me know if they are unable to for some reason.
Badger
Will do. Thanks Ray.
Badger
The support at the server proved everything was okay. The issue was some of the files were encrypted so simply decrypted and re uploaded and all works fine now. Thanks, Best, Badger.
