All of my pages that use IRite are no longer showing the bounded text fields
Everything is gone. I have tested locally, at Network Solutions, and at Big Daddy. Last week everything was fine. No... Nope.
I'd need FTP access and a url where I could reproduce the problem in order to debug this. There simply isn't enough information in your post to diagnose the problem.
What website url should I be going to and what should I click on in order to see the problem?
Go Here
http://www.gaskinscoating.com/admin/loginA.asp
This is such an old version of the editor... It may not work properly in modern browsers.
I think you best solution is to download the latest version from: http://ckeditor.com/download
Then use the new client-side implementation that would still work in your old .asp site. It shouldn't be too hard to do. The server side code wouldn't have to change.
If you need help, this is something we could do for you on that page for the price of a premier support ticket ($100)
Ray,
Will this be able to bind to the required fields in the access database, for adding a record and/or modifying it?
I have never used it.
Yes the values will be the same from the server perspective. It will behave like a textarea added to the the page (in fact it will be one that turns into the editor)
