Count searches by logged in user
Thread begun 3/06/2017 2:39 pm by bjgarner241692 | Last modified 3/07/2017 10:11 am by Ray Borduin | 3413 views | 6 replies |
bjgarner241692
I need to count each time someone uses a search form.
To update the data, I am using:
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
  $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["button2"])) && ($_POST["button2"] == "form2")) {
      $updateSQL = sprintf("UPDATE members SET currentcount = currentcount + '1' WHERE mID=%s",
                       GetSQLValueString($_POST['nothing'], "int"),
                       GetSQLValueString($_POST['mID'], "int"));
  mysql_select_db($database_conn, $conn);
  $Result1 = mysql_query($updateSQL, $conn) or die(mysql_error());
  $updateGoTo = "search-result.php";
    $updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
    $updateGoTo .= $_SERVER['QUERY_STRING'];
  header(sprintf("Location: %s", $updateGoTo));
Unfortunately, not only am I not counting the search, but the search form does not load the results page so I assume it is a triggering problem, but I have not been able to find a working trigger.
If I change the form post from <?php echo $editFormAction; ?> to the actual results page address the search produces the correct result, but if I do that I have no way of triggering the count. I have tried putting the count on the next page but that did not work either.
How can I trigger this count AND submit the search?
Add the count code to the results page instead of the search page and then set the form action to the results page.
bjgarner241692
So I did that and of course the search works, but I the count does not update.
/* count */
  $updateGoTo = "";
/* end count */
also tried using WADBSearch1 as the target to no avail.
Considered and tried a trigger of if ""="". It did not work, but even if it had it would be less than ideal because it would count on a page refresh and probably clicking from page to page of results as well.
I think this:
should be:
Is the mID value set correctly in a hidden field? Why not use the Session directly? Also is the form method POST?
bjgarner241692
Yes, mID field is properly populated and value is passing, proved this out by calling it in the body of the results page.
Used the session variable to populate it and called the form value in the parameter simply because I was more familiar with the syntax to do it that way.
The call to field 'nothing' is irrelevant. When you use the built in Update Record tool it insists on two fields (One primary and one to be updated), however, it is not referred to in my update statement. Deleted it though and there is no difference.
Yes, form uses POST.
You have:
but your button value is "Submit", so it should be:
if ((isset($_POST["button2"])) && ($_POST["button2"] == "Submit")) {
bjgarner241692
That is it. Thank you very much.
