Go to Master Detail
Thread begun 3/05/2017 5:59 pm by cal114936 | Last modified 3/06/2017 2:54 pm by Ray Borduin | 1698 views | 3 replies |
cal114936Beta Tester
Go to Master Detail
I can't seem to get the Master Detail to work with MySQLi. Thanks for any help.
content.php?cID=1
MySQLi generated query
$Recordset1 = new WA_MySQLi_RS("Recordset1",$UTVjournalMySQLi,10);
$Recordset1->setQuery("SELECT feature.*, author.*, photographer.* FROM feature INNER JOIN author ON feature.author = author.aID INNER JOIN photographer ON feature.photographer = photographer.pid WHERE feature.active = '1' AND feature.cID = ? ORDER BY feature.cID DESC");
$Recordset1->bindParam("i", "".($Recordset1->getColumnVal("cID")) ."", "-1"); //WAQB_Param1
$Recordset1->execute();
Jack
This:
should be:
$Recordset1->bindParam("i", "".($_GET["cID"]) ."", "-1"); //WAQB_Param1
Where would I be able to choose this option in the dialog?
You would have to add it to the bindings before it would appear. If you (outside of the webassist interface) go to your bindings panel and click the plus button and then choose "URL Variable" and then type "cID" as the URL Variable to add. Then it will become available.
Dreamweaver doesn't know what variables you might pass into the page until you register them in this way.
